pulse width modulation PLC Simatic S7-300
majox
Oct 2006
Ba
I have Siemens PlC and I am trying to write program in SCL or other language. This program shut regulate temperature using pulse width modulation but I can't find any reference how to use PWM in Simatic manager. Does anyone have reference to manual where to find something about Simatic Manager and PWM ?
Pwm
This is about S7-200 series.
The function PWM is described in PLS counter. It is standard function from menu. It is working to high speed output Q0.0 and Q0.1.
It is PWM function wizard. Just follow steps.
By the way wizard creats pasword protected subroutine.
Look for PWM search in Siemens site
Ramunas
Hello Majox;
If you have a compact S7-300 CPUs (312C, 313C or 314C) then you have access to TF (technological functions) including specialized blocks for Pulse-Width Modulation (SFB 49, Pulse). We have used them exactly for the type of application you are describing.
The manual is called S7300C_TF_e.pdf, and you can search for it on Siemens support website:
http://support.automation.siemens.com/WW/llisapi.dll?func=cslib.csinfo&changelang=true&aktprim=0&siteid=cseus&lang=en
Hope thos helps,
Daniel Chartier
Hey guys, I have a client that has a v-notch chlorinator that doesn't run off a 4-20mA loop, it instead has two discrete inputs that drive the...
1,876
Help me. I want to create a PLC program Pulse width modulation (PWM) with Simatic PLC s7300. using SFB49. but I have never made it. is there who...
2,574
Hi, I am trying to write a ladder logic using PWM and INI instructions to actuate a fast switching solenoid valve at a range of frequencies. I...
11,271
how can I change an analog output just with the program not using a digital input? also I need to ramp up and ramp down the analog output please...
4,185
Hi, is anyone familiar with the pulse width modulation output on the SIMATIC s7-300 series? I've set up the count module in HW Config, and want to...
5,728
