PV C600 won't access Micro 830 tags
toofast22
Oct 2012
illinois
Hello,
I'm working on a project with connected components workbench using a PV C600 and Micro 830. I was trying simple I/O forcing to see if they are linked correctly and keep getting "Data Access error for alias tag......." for every button I press. I have the C600 going right to the serial port on the Micro830. I am using AB serial CIP. Does anyone know what the issue could be? On PV explorer it showed no errors in the comm verification.
I have never used a PC C600 with a micro 830 but I have used several with SLC500's and micrologix 1400's. I have seen the error you are describing. Most common cause is a cable wiring error or the wrong address in the serial comms setup. Are you connecting to the phoenix serial comms connector? I can tell you that the wiring diagram in the user manual is not correct (complete).
Is CIP Serial fully baked in version 2.0 of CCW ? Have you seen any release notes or technical documentation on it ?
CCW 2.0 must have been a soft launch.. I see it on the RA website but I didn't get any notification or promotion that it had been released. I was waiting for the 850's and CIP Serial support before trying out a Micro 800 series project again.
Try addressing an ordinary internal Tag, rather than an I/O tag. I wouldn't be surprised if they limited the writeability of the I/O tags.
I found the issue. Thanks for the responses. I went on rockwells website and it said I could only upgrade my revision 1.012 controller to 1.013 and there was no other options. I upgraded it and during the upgrade I noticed there was a 2.011, but on the rockwell website for my control the 1280-LC30-48QWB it said the only available downloaded was 1.013 for that controller so I just did that. Still didnt work so I said F it and did the 2.011 and it worked. I am not an expert on this stuff so I didnt want to download firmware that wasnt made for the controller. Really makes me mad though spent a long time trying to troubleshoot when if on rockwells website it just said 2.011 was the newest revision for my controller I'd be good.
Allen Bradley PanelView C600 won't show "0" values in numeric display / numeric entry Hi, I'm working with a Panel View C600 and when the value...
4,275
Does anyone have a spare PacDrive part# LMC600CBD10000? Not necessarily for sale, but to do a bench test. I have a CF image file, and I'd like...
1,265
I have a client with a problematic PacDrive LMC600. It also has a separate PNC_Controller (Profinet) module. The original problem with the...
1,938
Have a C600 Panelview that the display went out in it. It still has the configuration in it and the equipment is still running. Believe it is just...
1,604
we have PanelView Component C600 (2711C-T6T) and want to modify it, try to install PanelView Component DesignStation V4.0 in my laptop and one...
2,719
