PV+ comms through Equustek
Nevy
Apr 2013
Calgary
Hi I am trying to get a PV+ 1000 (Ethernet) to talk to a SLC 5/04 (DH+) through a Equustek DL4500.
I can setup a network on my PC easily enough using the "Comm Port Redirector" utility from Equustek/Lantronix that came with the hardware through RSLinx and I can see the DH+ network, even go online with the PLC. So I know the DH+ side of my network is fine and the hardware is functional.
So my question is, is it possible to setup a virtual comm port inside a PV+ 1000 and tunnel it through ethernet using the DF1 driver in RSLinx Enterpise as I did using RSLinx and the "Comm Port Redirector" utility software?
If not, is there any way to accomplish this application, Equustek or not? Maybe a different model?
If anyone who has experience with Equustek could give me some insight, that would be greatly appreciated. I have tried their technical support but they have never tested their product in this kind of application.
I will give a brief rundown of what was running before and what we want to change it to.
OLD APPLICATION
SLC 5/05 (Ethernet) --------------------ETH SWITCH-----PV+1000
Modbus
SLC 5/04
NEW APPLICATION
SLC 5/05 (Ethernet)
ETH SWITCH-----------PV+1000
EQUUSTEK
DH+
SLC 5/04
Essentially we want the PV+ talking directly to the SLC 5/04 and Comms must be DH+ and Ethernet.
Any input is greatly appreciated.
Good morning, I have a ControlLogix chassis set up with two Ethernet cards. One is for our plant wide network to access the controller and the...
1,598
I have a system that operates with one PV300 (near operator station) and a ML1200 in a panel some distance away communicating using DF1 over...
4,782
I have set up full duplex communications with an SLC503 through a 1747-KE(RS232 to 485 converter) module using the new ABDF1FD full duplex driver...
2,871
My laptop was dropped and is now useless. I have bought a new one, but it only has a usb port. I need to communicate with PLC's using the...
4,793
Is it possible to do program upload/download across SLC channels 0 and 1?
8,809
