Pv1000
slachan
Sep 2005
Toronto
Do anyone how or have a PanelView 1000 simulator? I know some of you have suggested to import the project into RSView ME and then simulate there, but i dont' have the ME version. Does anyone know how to do a simulation any other way?
In particular, i want to know if anyone has tried to display chinese characters, especially simplified chinese? do it work?
Also, if i overlapped two displays, for example "Opened" and "Closed". For the "Opened" tag, i will only show the word "Opened" when its corresponding tag is 1 and shows nothing when it is 0. Similarly for the "Closed" tag, only display "Closed" when its tag is 1, and nothing if it is 0.
If I have the "Opened" tag on top of the "Closed" tag and when the "Opened" tag is 0, would I be able to see the "Closed" message underneath? or would it still cover (block) the "Closed" message underneath its blank message?
Any help is greatly appreciated.
I'm not aware of any simulator for standard Panelviews.
You don't stack graphics on a standard panelview and make them visible or invisible like I see a lot of people do in HMI packages like Wonderware. (Not that I think it's a good idea in Wonderware either, but I digress.) To do the function you describe, you use a single multi-state indicator. That's one object that displays "OPEN" or "CLOSED" depending on the value linked to it.
I have a mer or apa file for Pv1000 (2711p-rdt10c) and i need convert this files for Pv5000 (2715P-T15CD-K). Are exist a conversion tool for this...
865
Hi, im looking to migrate a 2711-K10C10 to a 2711P-T12W21 Panelview Plus 7 Standard. I migrate the PV1000 application .pba file in FactoryTalk...
2,015
Hi there everyone! Long time lurker, first time poster. I am doing an SLC-5/03 to CompactLogix migration and am having an issue with a barcode...
1,059
Hi, I'm investigating the feasibility of communication between a old PV standard display and a logix L5X controller via the controller serial...
1,473
Hi all, Anyone manage to get this smorgasbord of hardware to cooperate with each other? PLC - Micrologix 1500 1764-28BXBAA CH1 config - DF1 Full...
1,502
