PV6+; FactoryTalk View Studio Expression Error
qingrou
Jul 2018
Seattle
Using PV6+, FactoryTalk View Studio to talk with PLC
The expression error that keeps popping up are tag/10 or tag/100 (which doesn't make sense). The syntax checks are valid. The errors usually come up shortly after program start up or after not going to the page containing the tag for a while. Expression errors prompts the diagnostic screen to come up and is quite bothersome to the operators; grateful for any advice, Thanks.
qingrou,
It would be helpful for us if you stated what versions of FTV Studio and PVP6 you are using.
One suggestion is have you installed the latest RA patches/patch-rollup.
Can you grab a screenshot or a photograph ?
I think that "expression errors" can really be communication errors underneath, if the expression relies on a Tag that doesn't exist or whose comms status is bad.
You can disable the "jump to Diagnostic Display" function in FTView Studio. The malfunction will still happen, but it won't cause the Diagnostic display to appear.
We are using Factory talk view studio - view machine edition (release 10)
Image of expression error -> https://drive.google.com/file/d/1mfkn-m-Zk4fJJjw6Palza1NTV_iRzZ05/view?usp=sharing
Valid if-else statements are also causing expression errors. So we thought the bug could be due to a communication error; however, tags not used in an expression do not experience the same bug. Another possible cause is type error, the PLC sends a DINT and is divided (by 10 or 100) in the Factory Talk program.
Thanks for your help!
Good Afternoon , I created a small FactoryTalk View application , and created a runtime. I want to download it to a Panelview Plus 6 700 ...
4,468
Hi Guys I have an application archive file .APA for a PV6 1000. The screen has failed and we have replaced with a like for like one. I am unable...
1,911
We are a Verizon Partner and we just received this notice: As of July 1st Verizon will no longer issue NEW Static-Public IPv4 addresses...
1,558
Greetings to all, IPV4 and IPV6. What? I know it's "been out there" but honestly i haven't paid a whole lot of attention to it. Earlier, for other...
5,208
Hi, I'm used to have window Xp for quite longtime with my programming, now the company i work with is using window 7 for some logix and Ftview...
2,779
