Hi all, i've got a bit of a problem establishing a connection between a PVP700 and ML1500. I have previoulsy done this on an identical machine from the nine pin port (port1?), to the PVP. However, the machines now have Net-Eni's connected to this port, which is being used for Line control (network comms via msg'ing).
Soooo. setup is as follows:
ML1500:
9 pin (port1?) ----- Net Eni (working)
8 pin (port0?) ----- PVP700 (cable used following 2711-NC21 pinout) <-- Issues, wont connect
I have port 0 set to auto in the HMI, and have rslinx enterprise in RSview setup with the target shortcut pointing to the ML1500 through the serial DF1.
Anything glaringly obvious wrong yet?
Also, am i right in assuming that the "comm port" reference in the hmi is offset by one, i.e. port0 on plc is referred to as comm1 on hmi?
I'm heading out to grab a Genuine AB lead, and try it on a seperate identical machine tomorrow, to hopefully rule out hardware issues with the existing cable / plc and hmi ports on the machine ive been working on today.
ML1500:
