PVPlus 1000 error
Udunit
Mar 2014
Woodstock, Ontario
33
Hi. We have a PvPlus1000 that is showing the following error code:
(LegacyDP0x002047D0) Timed out reading from block 0x00222E88
Can't seem to find out what this is. PV works fine but this error keeps popping up and is driving the oprerator crazy....which can be amusing at time :D
I got quite a few hits on the Knowledge base searching for LegacyDP
Try that if you have access!
If not, are you talking to a PLC5 from this PV?
Post as much detailed information as you can about the connection between the PV+ terminal and the controller.
What firmware revision is the PanelView Plus ? What firmware revision is the 1756-L55 ? Has the system been reviewed for backplane chip problems (the notorious Atmel bridge chip issues) ?
Has this problem always existed or has it recently developed ?
It's unusual to get a LegacyDP error with ControlLogix because usually a PanelView Plus uses Ethernet to talk to a ControlLogix using native CIP protocol, not the "Legacy" PLC-5 protocols.
But you might have some kind of PLC-5 address emulation going, or a DH+ link, or something else unusual.
LegacyDP communication errors were common ten years ago because DH+ links were more common, and because early PV+ communication drivers were less stable than they are today.
If this were my system I would be looking closely at the communication link to find out if I had bad wiring, or find a way to decrease the load on the network.
You can keep the problem from vexing your operator by preventing the communication error from popping up the [Diagnostics] display.
In FactoryTalk View Studio, the Diagnostics List Setup allows you to configure when the Diagnostics display will be opened up automatically. The defaults are when an Error or a Warning occurs. If you un-checked Error, the Diagnostics list shouldn't pop up automatically.
This won't fix the problem, but will make it less visible. If you really do have physical media problems or link capacity problems, you'll still have to deal with them eventually.
(aside: 10,000 posts ! I have DeviceNet to thank.)
The processor is a 1756-L55 Rev 13.34, PV - 2711P-T10C4D2 Ser A Rev B, Ethernet connection 1756-ENBT/A Rev 1.1. Problem just started this week. The maintenance are unaware of any programming changes recently. About 6 weeks ago a flow meter was added to a screen and that was all. Once we get some downtime I will shut down the display for them.
Hello all. Sure hope someone can help with this. I have a system down because it is dependent upon its PV1000 and operator inputs to run it. I had...
1,601
Looks like I'm experiencing a lot of "firsts" this week. Here's another: Loaded a program into a PVPlus 1000 (F/W 8) and PLC program into a...
1,623
Hello everyone, I'm working on FT ME v.7 (My setting are below) and I didn't insert any storage cards. Max. data points : 1,000,000 Path : System...
1,263
Hello everyone, I'm working on FT ME v.7 (My setting are below) and I didn't insert any storage cards. Max. data points : 1,000,000 Path ...
1,116
Hello Friends, I have PV+ 1000 HMI programmed by someone. I donot have .med/.apa/.mer files with me. I am trying to upload the .mer file from...
4,581
