Q02(H) Reverting to old program
Richard_123
Mar 2010
Bristol
Hi Guy's,
I am using GXIEC version 7.01 to program a Q02(H) PLC. Last week I left the PLC tested and working. When I returned to the PLC after 3 day the program had reverted to an older version of code. Has any one come across this? If so do you know how to avoid.
Sounds like someone cycled power and the old program was in the eprom/flash memory. Your new program was running from ram.
Just a guess but it has happened to me with siemens - it was my fault for not flashing the program.
No, this is not the problem. The CPU only has RAM and no Flash installed.
You say you don't have flash card installed... but are you sure you don't make confusion with internal standard rom boot settings?
Create a new project and upload prog.+parameters from your cpu.
Check exactly where your program is downloaded in cpu.
And check project parameters about booting project
bye
Max 🍺
Hey guys! I´ve been asked to install a SRAM-card in said CPU. But since i´ve not had any training in Mitsubishi CPU´s, i´m a bit confused on how...
1,914
Dear all, i am communicating between siemens and mistubishi plc using profibus. master 317-pn/dp slave mistubishi q02 please if any one...
2,681
Hi, Does, anyone knows HOW TO COMMUNICATION ONLINE between my notebook and MITSUBISHI PLC CPU Q02 ? because I tried many times always failed...
1,549
Hi All, I'm now working with PLC CPU Mitsubishi..CPU spec is Q02(H) CPU.. In this system there have networking Net-H (QJ71LP21-25) and master...
9,198
hi all, i'm new here. thank god i found this forum. i've been stuck with my university project for days, it's this, i've been assigned to do a...
5,439
