Q2 CPU com. port
sttchui
Mar 2008
kl
81
I just recently borrow a Q01CPU Mitsubishi comunication cable, but i just found out the CPU i be getting is Q02 CPU series.
1) My question is does Q2CPU have the same communication port as Q01 series??
2) How many type of communication port does the Q02 Series have??
Thank you!
Best regards,
sttchui
The Q01 & 2 have rs232 only, the q06 & above have 232 + usb.
If you need other communications then the QJ communication cards are available these have 232/485 & one is an ethernet card.
there is also a NETH card these give communications via coax to upto 32 other stations (q series), this is easy to configure.
dear all ... i would like to ask a question.. Can mitsubshi (HMI) which install on pc can communicate with seimens PLC model 313c cpu.
2,103
Using DS4.0 we seem to be having some problems changing a timer value via remote modem conntection. I have no problems connecting or compairing...
4,698
Hello all, I have a one problem. I would like to upgrade Mitsubishi PLC Q02 to Q03UDVCPU. I have Q02 program and I change to PLC type and try to...
153
Hello everyone! I need to connect to a DL205-1 CPU and, as far as I know, I need to use DirectSOFT 6 software for the connection. Is anyone...
69
hello s7-400h and wincc are connected to each other via Ethernet. I need help on how to do time synchronization
64
