Quad Encoder Testing
Tim Ganz
Dec 2010
Dallas, Texas
700
OT: What is the proer way to connect a quadrature encoder to a oscilloscope for testing.
This is a 2 trace scope. We are not using the z channel of the encoder.
Would it be a+ / a- on one trace and b+ / b- to the second trace. Would the a- and b- go to the ground clip of the probe of each trace?
Yes to everything you said. The range totally depends on how fast you are turning the encoder and so is impossible to answer.
Bryan
Encoder is 1024 PPR. I don't know how many pul;ses we may want to see on the scope. What would be a good number for troubleshooting? How many would you need to see on the screen to get a consistant reading?
Sorry if my questions are so out there. I was a maintenance mechanic for many years but my company shutdown so the job i have now you have to do electrical and i am struggling to learn it all.
1024pulses x 1750rpm = 1792000pulses/minute / 60 = 29866.67 pulses/second, or a pulse width of ~1/30000 second. If you set up each division to be 1/100,000 second, the pulses will be about 3 divisions wide.
I normally make sure I set up the voltage correct, and then start turning the knobs until the picture looks good, then I look at the settings to see what I did.
Does anyone know if any companies make a module to read quadrature encoder signals and provide feedback over Ethernet/IP? I have an application...
2,809
Hi, I am using a quadrature encoder using the A and B signals to calculate inches per pulse. Can someone help confirm or correct my calculation...
2,641
We have a quad monitor setup with FT SE and we are utilizing a header screen at the top of every display. when we open a new page we abort the...
106
Anyone have an examplen on how to generate a sine wave in Structured text. Help much appreciated, thanks in advance!
6,634
Has anyone successfullyrics communicated to an ASCO (automatic transfer switch) Type G controller w/ Emerson quad ethernet module from anow ABC...
1,374
