Quantum Unity PLC Memory Question
RRoc
Jan 2017
California
45
I'm trying to figure out how much memory I have available in a Quantum Unity PLC 140CPU43412AU. If you double click on the processor and go to the configuration tab it shows you have much allocation you have for your 4X register. I want to know if my 19MB PLC file will fit in this Processor, but I don't know how to verify how much all my code has taken up. It builds and runs fine in the simulation mode.
RRoc
Welcome to forum.
Change from simulation to standard mode, then build all for program. If build goes throught then it is possible to load. If memory full error, you have problem.
On standard mode you see memory comsuption on PLC -> memory comsuption, no need to go online.
On old unity versions it was also possible look memory consuption on simulation mode. But memory consuption shows correct amount only at standard mode.
On simulation it was at least earlier possible build program which didn't fit to real PLC and build all didn't goed trought for real hardware.
@Lare I have went from Simulation to Standard Mode and rebuilt. No issue with rebuild, but how do I know how much memory I have used so far.
We are replacing an old Quantum 140CPU43412A to a 140CPU43412AU. It cost about $9,000. I want to ensure we have enough space. Also don't want to find out any issues in the field. We are using some 4X registers for our Maple OIT, but that should not be an issue.
As part of a comprehensive site survey, I have to mobilise to a remote site (offshore). I have also been asked to take a backup of their PLCs, so...
2,254
Hi All, I have a Quantum PLC 140 CPU 652 60 with a memory card TSXMRPC007M. It's being setup as Data storage to have size of 512 kb and...
1,110
Hi, I am trying to interface some dumb serial devices within the Unity software for a Schneider Quantum PLC. I have a device for puting...
5,717
we are still running quantum plcs and proworx but because it wont run on any new computers we are starting to upgrade our systems to unity. the...
770
I have several Modicon Quantum 140CPU43412A controllers that I want to downgrade from Unity OS to Concept OS. I first swing at it was to use the...
1,564
