Question AB Micrologix and PanelView Plus communications protocol
hhhjr2
Apr 2013
nj
Hello, Hopefully someone can help me. I want a PanelView Plus that communicates with a Micrologix 1400 via Ethernet to communicate with an additional device. The additional communications device is a MONICO/Redlion DSP. Right now I have a GE Ifix SCADA configured to log data from the PanelView Plus. This is emission data that I am required to keep records for the DEP. I also have the the PanelView Plus using Data Store Plus recording the info as a back up. There is one component missing that I do not log with the PanelView Plus One of my goals would be to intergrate the PanelView Plus to communicate with the Red Lion Data Sanitation Plus LE, so I could log a tag with the Data Store Plus that is available on the Red Lion Data Station, but I am unsure if the PanelView Plus is capable of communicating with more than the PLC and GE industrial Gateway at the same time. One of my thoughts were to use ModBud via Rs 232 to communicate with the Micrologix and read that tag in the PanelView Plus but I think I may be able to use the already available Ethernet communications. Any guidance would be appreciated. Thanks HHHJR
The panel view and red lion should have no issues with communicating with each other and the PLC. If they dont already have built in driver (which i think they do) I know the panel view you can set up using a kepware driver. The red lion should be easy to set up and have everything you need.
Hi I've got a AB Micrologix 1200 and 6" C600 Panelview. I'm wondering if I have a tag on the touchscreen setup to set N7:0 to "1" and in my main...
1,897
I am currently backing a Micro Logix 1100 and no-one seems to have the file for me to upload from. Is there a way for me to upload the project off...
538
Hi, I am working with a Micrologix 1400 model 1766-L32BXB. With no input wires connected to the “in12” thru “in19”, I am getting 24 volts while...
228
Hi All, Looking for advice on programming MicroLogix 1400 with RSLogix500. Basically, I have a client who requested I make a "simple" program...
19
3,225
Firsts of all to make it clear I am novice at programming and controllers. I was called to a costumer who has four machines that do identical...
1,530
