Question about finding error.
fredz0003
Dec 2010
Houston
186
Good morning,
I came across an error and I found it after looking very hard, is there a way to go to where the DW is being called from the diagnostic buffer? Access address 1616 which could be an easy way to get to the FB where is being called from?
If you can accept that the CPU goes to STOP mode, then delete OB121 in the CPU.
When the CPU stops, you can choose the "Stacks" and you will find a lot of useful information. If you use the "Open Block" button, it will take you straight to the place in the program that causes the error.
I am trying to find good training material for s7 micro win sp8. Any help appreciated.
1,027
Hello all, I have a servo turning a small table on a machine I'm programming. I found that after a day the home position was getting off by a...
54
Hi, I just upgraded just restored a ftview hmi data and the trend file have question marks with no lines in the graph. How do i fix this?
16
Hey all, simple question. Once I create a Macro in my Factory Talk Project, do I need to trigger the macro to run somehow? Or are all macros...
114
I recently uploaded an aplication from a Panel View, created a new screen and now that I've downloaded it to the Panel View, all the texts have...
174
