Question about PWRFLEX Drives
PLC Pie Guy
Jun 2013
Halifax
1,144
Hey there all.
I have question regarding Powerflex drives. I have a bunch of drives on ethernet. What I am wondering is why do the drives plug directly into a switch with a straight thru patch cord and are completly visible to linx, 5000 and drive tools. Yet to go plug my laptop into the drive I use a 1203-USB converter. I know I cant directly connect ethernet from drive to laptop even with a crossover cable, why?
I'm not familiar with the "1203-USB converter" you mentioned, but I've never had an issue connecting my laptop directly to a Powerflex drive equipped with an Ethernet card. I've not had to use a crossover cable either.
What drives are you having problems with exactly?
I fell kind of silly now. I just realized taht I was trying to plug my eithernet connection into the programming port of the drive. To do this you must use the 1203-USB converter since this is not an ethernet port. But I can plug my laptop into the ethernet card with no issues. Sorry for asking a question that really is not valid.
You're probably talking about PowerFlex 40-series drives, which have an RJ-45 style port onboard.
That port is for 'Drive Serial Interface' (DSI), which is a superset of Modbus RTU protocol, connected using RS-485 signalling.
Because RJ45 connectors are so commonly used for Ethernet, it's a common mistake to assume that they are Ethernet. This could be especially confusing when the drives are equipped with a 22-COMM-E module which has an Ethernet port on one side, and a DSI port (a flat ribbon cable) on the other.
You might think it's a silly question, but it really doesn't matter.
What matters is if you're silly enough to ask it again in the future ;-)
I have a 120V relay, 120V DI card and a analog input. I was wanting to know if i could put a 24V DI and well as a 120V DI card on the same plc...
78
Hello again..trying something on an existing poorly written program and just wanted to double check something system is an A-B MicroLogix 1200 In...
192
Good morning! Let me start by saying, I am still learning about this type of HMI programming. I recently watched a video about recipes and how it...
180
I have some logic that I have written within a 5380 series controller that tracks the time an event is started, while the event is running an RTO...
107
I have an HMI 2711R - T4T Series B, and I want to know which PLCs, besides Micro 820, can communicate with it.
113
