I need a method of logging test failure values using a G308/310 connecting to a mitsubishi Q series plc.
Basically i want to log the failure value of 3 tests cyclically, i have configured an alarm based on the test value and then used alarm 1/2 to add the text "out of band",but ideally i need to display the failed value and then log the message for later analysis.
If this isnt possible, could this be achieved with a popup screen? and then use another tag to trigger the test value entry into the log?
thanks Steve
thanks Steve
