Question on infilink
pwmvsi
Dec 2007
Texas
Guys, I need to redo some infilink screens in Russian. Where do I get the font set and most of all, can I use that string table?
R
Yes, Infilink-HMI is unicode, so any font loaded in Windows will work in the string table. If you have an American keyboard, it is easiest to copy and past entries into the string table. To make sure Russian is loaded in your PC, visit a Russian-language website--Windows should prompt you to install the Russion font. You can give me a call at KEP with any questions: 732-935-1320 extn 332, or Skype rgdawson.
I recently uploaded an aplication from a Panel View, created a new screen and now that I've downloaded it to the Panel View, all the texts have...
154
I have never had the pleasure of working with a "Thermistor" until now and have a question. The Thermistor is a 10KOhm 4-20mA 2-wire device and I...
135
Hi All, So I have a main routine with an instruction that's executed by XIC "Run" I have a JSR located on a rung below it. In the logic for that...
240
I have a 120V relay, 120V DI card and a analog input. I was wanting to know if i could put a 24V DI and well as a 120V DI card on the same plc...
103
Hello again..trying something on an existing poorly written program and just wanted to double check something system is an A-B MicroLogix 1200 In...
200
