Questions about Modbus registers
HamzaAhmed
Aug 2020
Palestine
86
Hi guys,
i am trying to program a Scada/HMI.
The values i will take them from PLC using Modbus.
In the manual they said:
This address is not an absolute address of a Modbus register. It indicates register offset from the beginning of the address space for registers of selected Type.
For example, Address (offset) 1 for a register of a Holding Register type will match to:
Protocol address 40000
Data model address 40001
So i put the offset to 0 so the programe take the vaule from Register D0 and then the offset to 150 so it take the value from D150.
But i don't know how get the value from coils or outputs, i don't know how much the offset supposed to be to take the status of M0 for example.
can you help?
Thanks,
Hi guys,
can you help?
Thanks,
Which PLC and HMI/SCADA ?
The offset means that if you want register 0 you request register 1 on your SCADA/HMI, register 150 would be 151 etc.
You would need to change your ModBus function code to get access to other data areas assuming your ModBus Server (slave) will accept them
Thank for replying,
I am using PLC DELTA and Aggregate scada/HMI
How can i modify or change my Modbus function?
Address 40001 or 400001, with 6-digit addressing, in the Holding Registers field, corresponds to offset 0, address 40000 does not exist.
The relationship between internal registers of your PLC, such as D0 or M0, and Modbus addresses must be explained in your PLC manual, there is no fixed rule applicable to all PLC
To access other Modbus address fields, like Coils, you should use the appropriate Modbus function
https://en.wikipedia.org/wiki/Modbus
Yes i understand the process now,, thanks a lot.
But what i should do now? search for what? converting the plc register to modbus or what?
Check what Modbus Function codes your PLC and HMI/SCADA support, if it doesn't support FC1 and FC2 then you will need to map the Mx registers to PLC data registers which will be available on FC3 (4xxxxx)
i didn't understand
Which bit don't you understand ?
Firstly you need to understand how ModBus works in its simplest terms, then you need to check the ModBus support in both your PLC and SCADA system as the PLC may not accept the requests for certain types of data from the SCADA system
ModBus masters use function codes to request information from slaves, have a read here:
https://www.csimn.com/CSI_pages/Modbus101.html
Thank you, i understand now the modbus
Just i want to understand how to communicate the Delta PLC registers with the modbus, i couldn't find any resources or ways for that.
I had a quick search and here is numerous YouTube videos shown Delta PLC Modbus setup, not sure if is the same model as yours though
I don't use Delta PLC's so i have no idea what their ModBus capabilities are so I cant help any more than i have, sorry
No problem, Thanks a lot for your help, you were very helpful, i saw the videos but it is different.
Just a question: do you have a way or a video for Modbus registers mapping?
Hello, I am new to Codesys, and am trying to learn about it for a project we're developing. I've got a couple questions, but first a little...
156
I am using a Beckhoff PLC and trying to convert a REAL to 2 WORDS to send over Modbus. Does anyone know how to do this? Also how would I convert...
798
Hi Everyone, First Project with Siemens and I need to communicate via RS-485 to a Tank Level Hub using Modbus RTU. I will be using the CB 1241...
3,824
Hello Long time lurker. I am flailing around trying to figure out how to implement MODBUS TCP on a W2000 IPC that controls one of my company's...
5,888
Hello, I have a DirectLogic 260 PLC that I want to read modbus data into and issue commands to field devices. Right now, there is a CMore HMI...
2,113
