Questions on Function Block programming
Raptor50
Jun 2012
It
Hi, I'm programming a Micro830 PLC and Function Block Diagram using Connected Components Workbench. I'm trying to output a analog input that has been averaged, scaled, stripped off the extra decimal I didn't need. That all works fine, the problem is I can only output one time. I need a way to toggle FBEN on my function RA_STRING_TO_ASCII. RA_STRING_TO_ASCII gets fed a string, converts to bytes and get put into an array. I can toggle FBEN_TRUE and send out my analog reading on the RS232. AWT_1.Q would toggle the FBEN, but not the first time through. Any Thoughts? I'm attaching a .jpeg of my program.
Here is the url of my jpeg: http://rc.runryder.com/helicopter/rr/rrpw.htm?d=/helicopter/gallery/32504/&IN=1&a=0&s=0
Thanks, JC
rrpw.htm
Check your AWT instruction. It probably operates each time the IN goes False to True. You have to find a trigger that goes on and off each time you want to look at a new value. You could do it based on time. For example use a 1-second time trigger to look at the analog value every 1 second.
I am troubleshooting an outside vendor program where add on instructions are used as well as these user defined function blocks. I am trying to...
1,616
I’m a complete newbie with PLCs and electronics. I am trying to grasp why in the user’s guide section 5.2 Analog output range 0mA to + 20mA needs...
1,571
Hello All, I have a couple of questions about some functions available in Crimson 3.0 and was hoping that somebody maybe able to help me out. I...
2,908
Hello, first of all let me state for the record that I'm not a tech of any kind, I have limited experience with industrial automation devices, so...
151
Hello, My background is IT, and I have very little (effectively zero) understanding of PLCs. I have been tasked with acquiring version 2 of...
113
