add on instructions, function block questions
remullis
Oct 2012
Georgia
179
I am troubleshooting an outside vendor program where add on instructions are used as well as these user defined function blocks. I am trying to figure out what calls for the specific solenoid to be energized, but when I cross reference the tag I keep hitting a dead end on the logic that would call for this solenoid. Can someone explain to me the best way to troubleshoot these user defined function blocks. Attached is the block with the solenoid in question. Also the Add on's are not read only.
RM
Bad picture quality, and you need to open the actual AOI logic to understand what is going on.
If they are grayed out the integrator probably put some security/source protection on them. Which I would argue they should be open so you can review for understanding and troubleshooting should you need it.
In RSLogix5000 I am attempting to create an add-on instruction called "SWAP" which simply swaps the values of two integer tags. Here is what the...
1,968
Hello everyone, Currently I am translating my Siemens program (SCL) to Allen Bradley (ST) and i am having a little trouble using the Add-On...
1,525
Hi Everyone, I am working on project that the customer require no ADI. The standard project we have uses ADI everywhere. I am just wondering...
2,390
hi all, can you guys please explain the why we use AOIs? My understanding is that they can be used like templates, so we create them once, and...
2,534
Hello everybody, From user manual "ControlLogix SIL2 System Configuration", SIL2 Add-on Instructions is required to configure SIL 2 PLC...
1,163
