Quick issue with RSLogix 500
Shawn_Mac
Jul 2007
Halifax
I've run across this situation twice now and not sure why it is happening, but I'm sure I am not the only one to see this before and maybe someone can help me avoid it in the future.
I have a drive setup for 5 different preset speeds & ramps using a combination of 3 preset inputs from a Micrologix 1000. Program controlling is a basic grafcet step by step program with a few comparison and timing bits controlling the outputs for when the different speeds are required.
What is happening is that the rung is going true on the first run sequence on this motor but the output isn't, I can force the output, but I can't even toggle the bit. It's not latch unlatch the rung goes true and the program can't move on until this step is complete so it sits in the true with output remaining false. I thought maybe it was being given run condition in two spots at once but it isn't and I'm a little lost as to why the output won't go "high" when the rung is true in this case.
Any thoughts are appreciated.
The best bet is to post the code. There are so many good people here that you will get a great solution in a matter of a couple of days.
If the output is not used more than once, are you scanning that ladder, if it is not in the main subroutine?
Based on the OP's comments, suspect he has the same outputs on two or more rungs.
While this can be made to work with conditional subroutines, it is not considered best practice.
As brucechase mentioned, posting your code will get you the most comprehensive responses.
Ken you were right with that assumption and I didn't realize it was a problem (inexperienced yet), After I posted this I went back to testing the program and tested the machine again with all the presets on there own rung and it ran fine.
I had previously had it set up so the logic on each rung wrote to the combination of presets required to run at the selected speed so in one case there was one of the outputs on 3 rungs. Another lesson learned.
Thanks for the replies
Cheers
I'm trying to import a .prj file and I keep getting the error message: Project import error. i Any ideas how to get around this? Thanks.
77
Hi, I am looking for some help with a GE Fanuc Versa Max Micro Controller model IC200UDR001-BF connected to a Quickpanel mini display...
151
Hello, I want to plot a line on X,Y axis with defined start and end points on Quick Panel+. I use PAC Machine Edition 9.7, and it supports...
1,734
349
I have previously shared this elsewhere, so I apologize if you have already seen it. Here is a basic and quick introduction to Python for PLCs...
2,248
