Quick Rockwell Automation Software Question
May 2004
54
Hi, is it possible to program a SLC 500 with the Rockwell Automation Micrologix 1000 disk that has RSLogix 500 Ver. 6.1 & RSLinx Ver. 2.42 Programming Software on it?
I have no idea what you are asking. RSLogix has several versions now but all will program ANY SLC and ML EXCEPT the free download version for the 10 point Micrologix, as noted it only works with the 10 point ML>
From what I can tell the disk is an original Rockwell automation disk. It is Micrologix starter Pak.
So with the above reply I would say that you can't program a SLC with it.
Thanks John
RSLogix500 is the software developed for programming any SLC500 unit, the problem you may encounter is weather you have the necessary "key" to activate the program. Without the key the software has limited features available or is totally unuseable. Rockwell will often package demos of multiple programs on a single CD. The right key disk can turn a demo into a full featured programming package.
We're currently taking inventory on all our Rockwell software and to what host each activation is linked. Some of the activations are hosted on...
5,225
I'm trying to import a .prj file and I keep getting the error message: Project import error. i Any ideas how to get around this? Thanks.
82
Hi, I am looking for some help with a GE Fanuc Versa Max Micro Controller model IC200UDR001-BF connected to a Quickpanel mini display...
160
Hello, I want to plot a line on X,Y axis with defined start and end points on Quick Panel+. I use PAC Machine Edition 9.7, and it supports...
1,749
353
