quick thermocouples
memberpeace
Oct 2006
Midlands
40
Hi all,
I have heard open ended thermocouples have quicker response than the others.
Does anybody have information about that? Have they been sold in that way or is it standard t.couples that need to be cut?
Are there any other kind of them that anybody has known in K type that has quick response?
A thermocouple produces a voltage proportional to the temperature of the junction. In this respect, a thermocouple response is instantaneous. However, a T/C is not usually used to measure itself, its used to measure an object or environment. In order to accurately measure the temperature of an object/environment there needs to be sufficient time for the thermocouple junction to reach the same temperature as the object. Anything that slows down how fast the T/C junction temperature equalizes with the object temperature slows down the T/C response time. This includes sheathing, insulation, thermowells, etc. For fastest response, a very thin bare metal T/C bead attached directly to the object is desirable, but there are many other factors to consider besides fastest response. A thin bare bead is subject to mechanical and chemical damage. Sometimes the bead must be ungrounded and cannot be in direct electrical contact with the object being measured. You need to consider all those factors when choosing a T/C style.
You can buy T/Cs that have an exposed bead, or you can make your own out of the appropriate thermocouple wire. Most commercially produced thermocouples have a welded bead. You can also purchase your own T/C welder. You can also make your own by twisting the wires together and mechanically securing them. Even placing the two wires together under the same screw will work. If you are 100% positive that the object being measured is at a uniform temperature and the object can conduct electricity you don't even have to have the wires in physical contact, eg, one wire could connect to one end of a steel bar and the other wire to the other end, and as long as the steel bar is of uniform temperature you can accurately measure the bar's temperature.
With a little more info on your application you could get some good advice from the forum members.
"Exposed junction" is on the list of one vendor's choice of junctions for MgO style thermocouples:
Although type K is nickel alloys, it can still chemically react or corrode when exposed to various atmospheric pollutants. That's the trade-off for exposed junctions: the lack of physical protection and isolation from chemicals, corrosives and pollutants in return for fast response times.
These guys make the fastest thermocouples I have ever seen. They have one design (the first detailed in that pdf) that can have response times down into the microseconds!
Brian
I'm trying to import a .prj file and I keep getting the error message: Project import error. i Any ideas how to get around this? Thanks.
87
Hi, I am looking for some help with a GE Fanuc Versa Max Micro Controller model IC200UDR001-BF connected to a Quickpanel mini display...
166
Hello, I want to plot a line on X,Y axis with defined start and end points on Quick Panel+. I use PAC Machine Edition 9.7, and it supports...
1,754
356
I have previously shared this elsewhere, so I apologize if you have already seen it. Here is a basic and quick introduction to Python for PLCs...
2,256
