Quick way to import symbols from Panelview32 to RSlogix500
grnick50
Nov 2010
Ptolemaida
332
Hello,
I have a project in PanelView32 and also I have the RSlogix500 program without symbols. Is there a quick way to export the symbols from PanelView32 to RSlogix500?
If this is not possible is it possible to export and import from Excel?
If by "symbols" you mean tags, then yes, you can export a PanelBuilder32 tag database to an ASCII export file (*.EAS).
You can then import this file into RSLogix 500 using "Tools>Database>ASCII Import".
Leave everything alone in the first window and then select your *.EAS file in the next.
NOTE: Panelbuilder32 only exports the tag name, tag address and description when it creates the EAS file.
Regards
George
I'm trying to import a .prj file and I keep getting the error message: Project import error. i Any ideas how to get around this? Thanks.
78
Hi, I am looking for some help with a GE Fanuc Versa Max Micro Controller model IC200UDR001-BF connected to a Quickpanel mini display...
156
Hello, I want to plot a line on X,Y axis with defined start and end points on Quick Panel+. I use PAC Machine Edition 9.7, and it supports...
1,744
350
I have previously shared this elsewhere, so I apologize if you have already seen it. Here is a basic and quick introduction to Python for PLCs...
2,253
