QuickDesigner/Quickpanel/Proface communication question(s)
CNorris318
Aug 2016
North Carolina
Hello All,
I am just starting to learn how to communicate with HMI's (Total Control Quickpanel/Proface) and some guidance would be very helpful!
So far i've learned that you need Windows XP to be able to connect/communicate with these Interfaces.
So I have a Laptop that is running Windows 7 with Windows XP loaded on a virtual machine from Microsoft. I do not have any drivers installed (Wifi, Ethernet, etc.) on the XP side of things.
Is this something I would need to install for the HMI to Connect/Communicate with the computer?
I am currently using QuickDesigner 3.70 with a QPK2D100L2P, QPJ2D100S2P, and a QPI2D100E2P with the updated version of the HMI-CAB-C49 (USB-GPW-CB03A) cable.
I have installed the drives from the CD it came with to the XP Virtual Machine but i'm not certain I installed the correct ones or they installed correctly.
My main intentions is to be able to test the ports (if possible) and then move to transferring programs, downloading programs etc.
unless it is a quickpanel with a ethernet port, you should just be able to use the usb to serial cable that you purchased to download the program to the panel. You will need to setup the software to use whatever com port the usb cable creates.
I havent used that usb cable, I have always used the older style serial cable.
Diat150
Understandable. I've seen people say they use com port 3 and or 5 but all that shows up for mine is 1 & 2 but I can't get past it saying I need to make sure everything is connected. What am I missing/doing in-correctly??
did you connect it to your vm? I am not sure which virtualization software you are using but the one I am most familiar with gives you the option to connect a usb device to the running vm.
I don't believe I have tried that. I will try that and write my results as soon as I can!
Thanks!!
I have connected all USB options that are in the drop-down menu of the VM with no further success. (n)
I have provided a picture for better details!
you should be able to see what is going on in the device manager of xp under com ports. unplug the usb cable and see if one of the com ports goes away. You may have to install a driver for that cable in xp.
lso, do the same in your host os.
Hello and thank you for the quick responses.
I was able to change the COM port to any port number as it was set to COM3 as default. I didn't realize there was a 4 day trial on the QuickDesigner software. Are you still able to purchase serial keys for this? If i'm not able to get the full version running, is there a more updated program that will support these older HMI's??
You can un-install QuickDesigner then re-install it for another four days.
Yes there is a more modern software to use for this, it is Proficy Machine Edition View from GE. Contact them to purchase.
Be away though that using ProficyME for the quick panels does change some styles fonts and whatnot and I also found the older the panel it was the slower it was after using PME instead of QuickDesigner. But PME is also more user friendly IMO.
That was the case with early versions of Proficy ME View, however the lastest versions do a very good job.
ALWAYS keep your software up-to-date. :)
Haha. That is good to know. I do agree on software up to date. But in this case I was provided the software by the customer... thanks for letting me know RussB
Ok so i've run into some problems.. I had to reinstall VMware software and get XP Mode back up and running. The version I am running now is different than the one I showed in the previous picture. I am unsure what version that was but the one i'm using now is 7.1.4. I am getting an error when trying to connect the drive to the XP-VM. The driver comes up fine in W7. I have installed the drivers on the XP-VM. What version of VMware works best for you all?
The first picture is when it's connected to W7 before I try to connect it to XP.
If you notice at the bottom of the XP-VM window, it shows the error.
Screen shots don't tell me much but it is likely that you can't have the USB used by both the host and the XP-Mode VM at the same time.
Hi, I received the following project from a customer on a QuickPanel Proface 6" that I need to swap to a Siemens Panel. However, I cannot seem to...
345
I am having issues loading an older Quickpanel Model QPICTDE0000 with the .prj file that was supplied. Every time I try to import the file into...
1,699
I've been resurrecting an older machine from 2005 and have had good success with help from the forum. Got connected to the PLC and was able to...
1,390
I have a Total Control QuickPanel JR and i need a QuickDesigner software to programming this HMI. Does anyone have this software?
1,067
Hello. I am looking for the GE Fanuc software QuickDesigner V2.x (for example V2.4 or V2.2) in order to download to an old Quickpanel QPx-1 Can...
2,154
