Codeblue
Hi all,
I was looking all over the internet for a QuickSort function implemented on a PLC but could not find one anywhere so here is one I have written using some C code as a template. See https://en.wikipedia.org/wiki/Quicksort AND https://www.toptal.com/developers/sorting-algorithms
Quicksort2: Implements iterative quick sort without the use of a stack.
Returns a sorted array and an array containing the index order of the original array.
This was written in ST using Schneider Control Expert V14; I will include the TXT below for all without CE V14.
Code:
Quicksort2: Implements iterative quick sort without the use of stack.
WARNING: All Array sizes must be matched.*)
(*INITALISE VALUES*)
(*elements := UDINT_TO_INT(SIZEOF(IN:=INPUT_ARRAY) / SIZEOF(IN := INPUT_ARRAY[0]));*)
MAX_DEPTH := 300;
pivot := 0;
i := 0;
L := 0;
R := 0;
swap := 0;
LeftArr[0] := 0;
RightArr[0] := elements;
ARR := INPUT_ARRAY;
FOR n := 0 TO (elements-1) BY 1 DO
INDEX[n] := n;
END_FOR;
(*SORT*)
WHILE (i>=0) DO
L := LeftArr[i];
R := RightArr[i]-1;
IF (L<R) THEN
pivot := arr[L];
pivotPos := INDEX[L];
WHILE (L<R) DO
WHILE ((arr[R]>=pivot) AND (L<R)) DO
DEC(R);
END_WHILE;
IF (L<R) THEN
arr[L] := arr[R];
INDEX[L] := INDEX[R];
INC(L);
END_IF;
WHILE ((arr[L]<=pivot) AND (L<R)) DO
INC(L);
END_WHILE;
IF (L<R) THEN
arr[R] := arr[L];
INDEX[R] := INDEX[L];
DEC(R);
END_IF;
END_WHILE;
INDEX[L] := pivotPos;
arr[L] := pivot;
LeftArr[i+1] := L+1;
RightArr[i+1] := RightArr[i];
RightArr[i] := L;
INC(i);
IF ((RightArr[i]-LeftArr[i])>(RightArr[i-1]-LeftArr[i-1])) THEN
swap := LeftArr[i];
LeftArr[i] := LeftArr[i-1];
LeftArr[i-1] := swap;
swap := RightArr[i];
RightArr[i] := RightArr[i-1];
RightArr[i-1] := swap;
END_IF;
ELSE
DEC(i);
END_IF;
END_WHILE;
