RA_Real to String
damica1
Aug 2015
Illinois
839
Some where on Rockwell Automation sample code section there is/was a function for Connected Component Workbench. This function takes a REAL number and converts it to a STRING. I can't find it anymore. It was named "RA_Real_To_String"
Can anybody point me to this - so that I can download.
What version of CCW are you using?
Version 9.00 has an ANY_TO_STRING command which will do the conversion, however it will represent the real number in scientific notation. I had to create a function block to display real number the way I wanted to.
I am using version 9.
You are correct about the "Any to String". - That is why I am using the "Real to String" because it will take a real number and covert to a string with 2 decimals. But I have lost the documentation and I don't remember what the "Unit" input is actually for.
And now I can't find it on Rockwell Automation web site, I have searched for days. It's like they have removed it. NOTE: The RA at the beginning means it has been approved by Rockwell.
Hi all, I've got a bit of a need to convert an integer (and a real in another situation) to a string with a particular format. This seems possible...
2,460
First all please forgive my poor English language proficiency. I already successfully setup a analog tag reading data form PLC. Then I want to...
1,846
Dear Sir, I try to write a function use SCL to read the string from a DB and convert it to real and transfer to another DB. But the simple...
34
25,033
I have a string '+0022.345' that i am getting from the serial port the number will be positive or negative that i need to work with can someone...
2,117
Dear all, I have following problem. I'm sending an SMS when i got an alarm. For now I'm sending "Temp to high" but now i want to change this...
3,895
