Read address MD from OB1 block
Yogthothot
Mar 2020
Kiev
Hello everyone! I want read MD address (temp data) from OB1 block and save data on PC. Program working on VIPA S7-300.
I try used moka7 (java library) but cannot get read address from OB block.
Who can help?🍻
Welcome to forum.
Thinking that you need first copy temp data to different memory area on PLC, as temp data gets writed over on PLC program if you have code on PLC.
Welcome to forum.
I can`t change code in PLC. I know touch panell WEINTEK read OB1 area
Any data in the temp (l stack) gets lost at the end of every scan.
Move the variables needed to global memory such as a data-block or to the Marker memory (m).
Regards
Daniel.
Dear friend, how to read the input register (3xxxxx) of device from twido plc. i have tried the comm macro but it always read the holding register...
1,569
Hello, I have a radio telemetry system that has an RS-232 interface that "understands" the DF1 protocol. In one place I still have a Compact...
2,109
Hi everyone, I'm looking for a way to read the IP address I set on my 1756-EN2TR card. I want to use it for internal logic in my controller. No...
2,580
Hi! I'm trying to understand the structure of the "Protected Typed Logical Read with Three Address Fields" function, and I am using the online...
1,637
Is it possible to read the IP address of the Panelview terminal from its internal registers...perhaps to display on the screen??
2,100
