LuisR2D2 Member L Join Date Nov 2023 Location Mexico City Posts 3 Nov 9, 2023 #1 Hello hope you are doing well! I wan to read the next parameters of a VFD 525: 1. Output Current 2. Average Power 3. Energy Saved to display them in a time series, however I don't know how to add them to the "Controller Tags" SECTION. Will you help me out please?
dmroeder Lifetime Supporting Member Join Date Apr 2006 Location Vancouver, WA Posts 3,604 Nov 9, 2023 #2 How you do it depends a bit on what version, the drive tabs are organized different. In my version: Open a drive, click Device Definition, Connection Format, pick new parameters on the input tab.
dmroeder Lifetime Supporting Member Join Date Apr 2006 Location Vancouver, WA Posts 3,604 Nov 9, 2023 #3 Edit: Double post
JaxGTO Member Join Date Apr 2009 Location Kalieefornia Posts 1,071 Nov 9, 2023 #4 I believe you can read multiple parameters from it using a message instruction. Search AB Knowledge base for what registers to read. The passed parameters are limited.
dmroeder Lifetime Supporting Member Join Date Apr 2006 Location Vancouver, WA Posts 3,604 Nov 9, 2023 #5 Sure can. GetAttributeSingle, class 0x93, instance parameter number, attribute 0x09
joseph_e2 Member J Join Date Dec 2010 Location Harrisonburg, VA Posts 1,093 Nov 10, 2023 #6 There's a user manual for the embedded Ethernet adapter: https://literature.rockwellautomation.com/idc/groups/literature/documents/um/520com-um001_-en-e.pdf The section on Explicit Messaging was very helpful. You can read a single parameter or do a scattered read of multiple parameters.
