Read multiple RS-485 ASCII into MicroLogix 1400
icsbrad
Oct 2012
Nebraska
Hi all,
I would like to read ASCII weight from 2 scales into a single serial port on a MicroLogix 1400 using RS-485. I haven't seen any posts on this before, is this even possible? I will be integrating 2 scales that are addressable and spit out thier weight 1 / second (RS-485 ASCII). I would like to wire them up on a RS-485 multi-drop network and monitor each one individully using the same comm port on a MicroLogix 1400. I currently have one of the scales setup and working with the ML1400 by using either port 0 or 2 as ASCII and reading the data with the ABL and ARL instructions but wasn't sure how to accomplish this without using a gateway as it looks like the the MSG instructions would only be used for Modbus RTU, correct? Thanks in advance for any advice.
Hello Friends; We have 10 NOS. the machines which were designed in RSLOGIX 5000 and the control system is TT4000 by SOLAR TURBINE. I want to...
3,858
Dear Experts, Can you help me, I am using compactlogix cpu with ILX34-MBS485 card as Rs485 master in serial modbus network to make communication...
2,830
I have twelve ControlLogix controllers spread throughout an oil production facility with local Panelviews on each unit. All PLCs are connected...
3,596
Hi! Can anyone help me with ModBus TCP Read Multiple Registers(Function Code 03)? I have a Master Request: 00 00 00 00 00 06 01 03 64 06 00 07...
3,933
Hi all, I am writing a program where the user will input a bunch of individual registers they want to read. I am going to sort these registers...
13,715
