Reading Analog inputs Automation Direct PS550
mzdeilami
Oct 2013
LC
I just started working with automation Direct PS 550 and its software productivity Suite. I need to read some analog inputs but I dont know how. I tried to read it's manuals but couldnt find anything helpful.
I'll appreciate your help.
best,
Z
Thanks for your reply,
I read that manual but it's only about the hardware configurations. I have problems in reading the input in the software.
Im using a P3-16AD-1 Analog Input card.
best,
Z
Sorry for the delay in getting back to you.
Since you mention seeing the hardware manual do you have the module installed and properly wired to 24VDC power and you current input(s)?
The manual shows a view of the 'Module Configuration' in the P3000 software. Is yours filled in properly?
Do you have a running program in the P3000? Do you have a signal applied to an input? Do you see varying numbers, corresponding to the level of the input, at the variable location shown in the 'Module Configuration?
I'm pretty new to Siemens. I just downloaded a new program into a new S7-1500 CPU. All modules are ok/not faulted. here is the problem: i have 4...
2,927
Hi All, I'm brand new to DirectSOFT 5, and fairly new to PLC programming in general, so go easy. I was handed a program with no information on...
2,432
Hy I am new in PLC field we are purchasing S7-300 PLC.I want to know how analog inputs are read and interfaced with S7-300PLC.Kindly help me in...
1,941
I am setting up a new system and have an s7 1214 plc with an sm1231 4x AI (6ES71231-4HD32-0XB0). It is configured for 0-10v and has no faults in...
1,159
I just added a 1746-NI4 in remote rack slot 9 and ch0 is set to 0-10V input. Now I am trying to read the AI and the value getting back from BTR is...
2,258
