Reading data via ethernet
Maik Fuchs
May 2005
Aarle-Rixtel
22
Is it possible to read data (DB) from another s7-300 plc via ethernet without implementing the plc in your project. Via MPI this is possible, i have done this before. I used "X-Get" SFC-67 for this.
The only things i had too know was the MPI address and of course where the data was located.
Now I know the IP address but the PLC is not on the same MPI network.
Hi all, Has any of you got any example of reading data from modbus tcp, using FBD? I am just trying to get my head around, doesnt look like a...
2,547
Hello guys , i'm stuck and can't figure out how to make a communication between foxrtu station (soft to configure FOXBORO SCD2200 RTU with...
2,021
Hi to all! Need some help! I'm reading CATERPILLAR engine data of a natural gas compressor into my MVI56E-MCM card. The card sits in a 14 slot...
3,630
Greeting, I have some problem about reading FX2N-4AD data. Below is my connection Q2PLC - Connect to FX3U with CC Link In 1st node, I have...
1,864
162
