Real Time Clock Micrologix 1100
jrrivera
Feb 2010
Tamaulipas
I have a problem with the RTC in a micrologix 1100, it doesn´t work well, the time always is incorrect, I send the time and the plc accepted it fine, but the PLC always is delay with a hour or more. The PLC is new.
Some idea to fix it?
Thanks.
The RTC on every MicroLogix 1100 and 1400 controller I have used worked correctly.
Is the RTC always off by *exactly* an hour ? Does this appear immediately or after a few hours or days of operation ?
Are you doing any logic that writes to the RTC ?
No, the PLC inmediately starts with the delay when I send the time, I am not writing any logic to the RTC. I have other Micrologix of this type and I haven´t this problem.
Post your .rss file ( zip it first)
Is there a HMI connected to the ML1100? If so disconnect it and see what happens to the time.
Please state exactly how you "send the time". How are you viewing the result to decide that it is delayed. Are you noting that an expected function is delayed or are you observing the time values themselves?
Hi all I thought I had this working but upon doing a checkup a few months after the machine was commissioned, I found that adjusting the RTC via...
1,865
Hello all, Long time lurker first time poster. I appreciate all the advice you guys provide. I've learned a lot. I am seeking an answer to...
5,392
Hello Guys, i have a question. Is it posbile to start the real time clock on a Micrologix 1400, from ladder. When the 1400 (new) arrives, the...
23,075
OK let me first explain how I am doing something and then you can tell me how I can do it better. I move the current day, Month, Hour and Minute...
7,697
I'm using the RTC in a MicroLogix 1400 and I want the operator to be able to set the date and time via an HMI (brand irrelevant). The HMI can't...
9,290
