Reccomended Joystick
Brijm
May 2006
St. Marys, PA
645
I wanted to see, if anyone had a distributor (preferably in the U.S.), for small industrial joysticks. It's going to be directly controlling a +/- 10V Proportional valve for loading logs from the deck to the re-saw. I was planning on a potentiometer, preferably with a center tap. It will be mounted, with 30.5mm buttons, so about that size would be best. Only need single axis, but would consider dual axis, if it is easier to get.
Any reccomendations are appreciated....
-Mur
Brijm,
Take a look at Penny and Giles line of products. Specifically, the JC150. It seems exactly what you're looking for.
Here's the URL:
http://www.pennyandgiles.com/products/products.asp?strAreaNo=402_9&intElement=1195
They're extremely reliable and durable, and when properly mounted, they're IP65 rated. A 42mm hole is needed, so it's a little bigger than the other buttons you want to use. The only other downside is that they need a relatively deep panel for mounting. This may or may not be an issue for you.
I've used them them several times for winch systems for flying performers in harnesses for theatrical productions (I build automation systems for theatrical and film special effects). I wouldn't use something that wasn't 100% reliable for something like that.
I hope that helps!
-Ryan Poethke
Thanks for all the reccomendations... I went with a ETI series J9 joystick, with inductive circuitry. I don't need high precision, just a little bit of speed control for a hydraulic log loader.
Thanks again
-MUR
i am looking for recommendations on programming languages/courses to learn to further my skill in this field. I have been a PLC/Robot programming...
2,397
I'm building a hydraulically-operated tractor-mounted boom that will be used to read temperatures within bulk material piles. To simplify the...
681
Hi all, I have a function where I have to use Joystick to control the solenoid valve. I am using Joystick as an input to PLC(micro820 or micro850...
2,400
We have a project that has existing proportional valves and joysticks that they're using. The customer wants to eliminate the controller/driver...
1,764
We have an application where we need a joystick to control a VFD. Off in the center, 0-10V in forward and 0-10V in reverse. Also with auxiliary...
2,344
