RecipePro questions
Jan 2003
Michigan
490
I am trying to write an app using recipe pro (and RSView 32). What I am attempting to do is give the user the ability to enter the recipe data into a series of tags, and then click a button to save it to a recipe name. The problem seems to arise from the fact that any "save" button has to be hard coded for the recipe name. SO, if I have 500 recipes, I need 500 save buttons. (The RecipeProUploadUnit and RecipeProDownloadUnit command MUST have a prestated unit). The same goes in reverse. So far, I must say, that recipe pro is a pretty pathetic program.
Am I wasting my time ever trying to beat this joke of a recipe program into shape? Would I be better off just using RSLogix and writting it in ladder?
Matt
I've never been a fan of 'recipe pro', which originated with ICOM's WinView.
You can probably get better results with RSView's native recipe handling (which originated in ControlView) if the recipes are not large or complex.
Otherwise, bite the bullet and tackle the problem with RSView's VBA and perhaps a database.
I would advise against doing it all in the PLC. Too easy to run out of memory, too easy to lose recipes if you download a program, too difficult for operators to make backups.
Good Day RecipePro + Does anyone have much experience with this product? We are looking into a utility where we can store values and assign to...
1,453
Hi all, i need help on how to use Recipe for FT SE. I read the manual, it mentioned about RecipePro+. However i cannot find in the software. How...
1,546
Hello, I am still working on a conversion project from RSView32 to FTV SE. It appears all the recipes on the View32 system were stored in...
3,749
How can I keep RecipePro in RSView32 from omitting the leading 0 in my data set. For example, my recipe data value is .123, but when this value...
1,561
Hello, Here is a little history. I just inherited a project for which many details are unknown, and the machine is a plane ride away. There is...
3,380
