Record maximum value in Wonderware InTouch
vojvoda82
Sep 2010
Sybiria
hi there,
I have a tag in which is stored realtime value of voltage. I'm need a way to record a maximuum value of this voltage and dispay it on some InTouch or ArchestrA simbol. Is there any way to do this whitout using wonderware historian?
It sounds like you do not need a history, but only a single max number. Depending on how fast the data is changing, and how accurate you need to be I would do this in the PLC. Communication normally does not scan very quickly on an HMI.
You can use a data change script, but I'd just put the logic in the PLC myself.
In either event, the basic logic is just:
IF Actual_Value > Max_Value THEN Max_Value = Actual Value
I'm a beginner at this, I have points with x y z coordinates that I want to record on s7-1214 and use to move the axes for those points. How can I...
170
Good People of PLCTALK. I am trying to understand the pass-fail on one of our product lines. I was able to record the Cognex images on the...
248
Hello, I am sending data from a siemens 319-3PN/DP Plc with a Additional Cp343-1 card from the Plc to a remote BNR pc. I have configured 2 tcp...
2,184
My AB PLC got fault record in CF card.But I dont know how to open it.Could anyone help me?
1,523
I've hit an emergency situation with an older setup that controls a critical system. There's a Windows XP "server" that interfaces with a Rockwell...
2,685
