Elcan,
I just tested this again and it is working.
If you update from the USB stick, the next update from USB stick must be a file with a new identifier and the previously loaded file must have Memory stick support and updates enabled. Your file will receive a new identifier by being a completely new file. Meaning you went to File > New to create this file or if you are making changes to an existing file you need to first go choose File > Save As which will prompt you to assign a new identifier. After choosing yes you can then save your image and load the file via memory stick.
Jeremy
Jeremy
