Red Lion CSMSTRSX, How to call a program?
1. Go to the triggers section of the data tag
2. Set the trigger mode for change of value and set the value to 1
3. In the action box type the name of the program followed by (). ex: Program1()
Jeremy
Hi Guys, I know nothing about this little gizmo except the IP address. It is being used as a data logger. We access it via the ethernet...
2,575
I'm using a RedLion G3 with modules CSini8 and CSDIO14. It has a modem installed with an ATT sim card. A static IP address has been assigned. I...
4,732
Hello everyone, I have a water treatment skid that uses an Allen Bradley Micrologix 1500 PLC and the Red Lion data logger model CSMSTRSX. I had...
5,869
Is there a way to copy all of the Communications (blocks) from a DSPLE application to a CSMSTRSX application? It would be okay if there was even...
2,175
While they came up quickly with a fix for the alarm date issue quickly I will have to drive around for a week or so, burning up a lot of fuel...
267
