Red Lion Data Station Plus Question
Jmoreno111
Apr 2015
San antonio
Good evening. Hoping someone here can help. I am working on pulling a floating point data tag from an Allen Bradley Compact Logix to a Red Lion DSP (1). This particular Red Lion is an existing station that is connected via cellular network to another remote Red Lion DSP(2). I am not able to monitor the data tag connected to the Compact Logix and I believe that my problem is with the data tag setup. I'm basically not able to transmit data tag info from the Allen Bradley Compact Logix to Red Lion DSP (1). Ultimately, the goal is that once data tag is transferred to Red Lion DSP (1) we can transmit to Red Lion DSP (2) at the distant end. Right now, I'm just trying to ensure that the tag is being received in the Red Lion DSP (1). I've followed the DSP tag setup using the .L5K procedure and linked the tag to a tag created in the DSP and updated the changes. However when I attempt to monitor the tag in the monitor window where the numeric value should appear n/a is displayed. I have compared an existing and working tag and have attempted to replicate with no success. any help would be greatly appreciated.
Welcome to the Forum !
There are quite a few veteran Crimson 3 users here, and some enthusiastic novices (like me), who can probably help.
Can you ZIP and post the *.CD3 file ? Ideally also post what revision of Crimson 3 it was created in.
Getting the driver configured and the syntax right the first time can be tricky in the ControlLogix drivers.
Also: what firmware revision of CompactLogix are you running ? I have not used Crimson 3 for Logix 5000 higher than v20, personally.
I`m looking into using Red Lion Data Station, do someone have experience with limitation on number of tags and performance?
1,731
Hi I have been using Red Lion products for some time, I had a thought over the bank holiday weekend, As you do. It would be nice if whenever a...
1,022
Hi, I'm trying to get values from 8 encoders using a 2-wire bus RS485 connection to a Red Lion Data Station. These will ultimately write values to...
2,373
Hey everyone! Pretty new to Red Lion, and am setting up a data logger on my HMI application. My boss is logging data on another HMI and I've...
2,350
Hi All, I am hoping someone can help. I have setup a Red Lion Data Station (DA30D, Crimson 3.1 Build 3112) to log data from several Allen...
18
7,361
