Red Lion Data Station to S7 1500 plc
pauly
May 2002
South Wales,U.k
244
We have a project where there are a number of areas of plant that need to monitored (around ten areas) and as the customer has only specified the number of data points and the mix of data from each area (some discrete data on hardwired I/O and some across communications networks, profibus, Modbus TCP/IP to be confirmed) I was thinking of using a Red Lion Data Station Plus in each area to act as a communication master with some local I/O on Modbus TCP/IP and networking all ten Data stations to a central Siemens PLC. The reason for the Red Lion Data station is that they are flexible in the protocols that are available.
My question is has anybody networked Data Stations together before to a Siemens PLC?
The reason for the PLC is that there could be some control involved as well and a SCADA system connected to the PLC.
Thanks for any help
I`m looking into using Red Lion Data Station, do someone have experience with limitation on number of tags and performance?
1,738
Hi I have been using Red Lion products for some time, I had a thought over the bank holiday weekend, As you do. It would be nice if whenever a...
1,028
Hi, I'm trying to get values from 8 encoders using a 2-wire bus RS485 connection to a Red Lion Data Station. These will ultimately write values to...
2,375
Hey everyone! Pretty new to Red Lion, and am setting up a data logger on my HMI application. My boss is logging data on another HMI and I've...
2,351
Hi All, I am hoping someone can help. I have setup a Red Lion Data Station (DA30D, Crimson 3.1 Build 3112) to log data from several Allen...
18
7,377
