Red Lion G310
Not tried it so it is a bit of a guess.
In Communications/Network/Protocol you can select Raw TCP/IP Active or Passive, not sure which to use.
Look top right and it tells you the Port Number.
You can open a file with Handle = OpenFile(FileLocation, Mode)
And you can read a file line by line using Line = ReadFileLine(Handle)
You send some text out of a port using:
PortPrint(PortNumber, Line)
Hopefully someone smarter will kick in, but it might get you started.
Hello, We are currently running a bunch of g310's connected to their SLC5 PLCs through ethernet. I've attempted to upgrade the program from 2.0...
1,124
Hi. We are currently experiencing slow loading or response time on our Red Lion G310, at about 5-10 seconds delay once we press a button or even...
1,622
This is my first time using these two, and I have picked it up fairly well. I don't have much programming experience(very, very little), but I...
1,633
I currently have RS Logix set up with a ladder logic program, when I force inputs from RS Logix I can get it to update the Red Lion G310 HMI...
2,061
I'm developing a project using the red lion G310 HMI. I didn't get yet the device but i'm using now the crimson 3.0 emulator. I must communicate...
1,557
