Red Lion Modular Controller count value
Bunger
Sep 2009
Connecticut
Could someone take a quick look at this simple program and tell me why my counter is not working.
Basically I want input 1 to advance the counter by 1 on every input.
The data logger confirms that input 1 is working but the count stays at zero.
I have not used the Logic Editor but a quick guess would be you have a preset of 0 and sometimes preset counters will stop counting when they reach preset
try entering a value for preset and see if that works
To start with, your logic editor shows that you're using inputs 2 and 5, instead of 1 and 2 as your variables are assigned.
edit: nevermind. I think you need to initialize the module conifuration to "include in download" and "Run" the logic engine.
Preset zero means that it will count to 65535 then return to zero. Do not want a preset. Confirmed that with RL yesterday.
I had already corrected my logic editor. Input 1 is the input to the counter, Input 5 is the reset on the editor only. There is no actual reset. Input 2 is unrelated to the counter.
Dear sirs I'm using Red Lion products and now I have 2 problems to ask you here. 1) I use CSMSTRLE as a protocol converter [Modbus RTU to...
1,288
I'm using Red Lion Modular PID controllers with Automation Direct Productivity PLCs and HMIs. I have 10 heating zones, each with their own module...
1,353
In a Red Lion modular controller system with a base unit and ten two-channel loop controllers, one or more of the individual modules will...
1,795
Hi, This is my first time trying to configure a Red Lion CSMSTRSX controller and I have bumped into a roadblock. My objective is to set up a...
1,183
Can't find the terminating plug for an old Data Station - I get 4 blinky status lights. Is there a short term work-around until i can buy a new...
1,589
