Redlion Crimson: Change TCP port in a program?
billysmithde2
Jan 2008
boston
21
Using Crimson with G3 panels and the master controllers, four TCP/IP protocols are allowed. I would like to access a 4 port serial-to-ethernet adapter and provide several other TCP services (ethernetIP and Modbus) at the same time. Problem: All four serial ports require different TCP/IP ports (e.g. 4001, 4002, 4003, 4004), so that seems like it would consume all four Ethernet protocols allowed. I would like to assign one Raw TCP/IP Active protocol and in programming cycle through the four ports mapped to the four serial devices with the required custom serial code depending on the devices attached. Anyone know if this is possible?
There is currently no way to change the port via programming. You are correct that the only way to do it right now is to use all 4 protocols. I submitted a feature request for a programmatic way to change the TCP port.
Regards,
Dan
Hi everyone, I am hoping to be able to program the Redlion Productivity Station to change the pages with some conditions. I hope to be able to...
4,147
Hey guys, hoping someone here could give me a little advice. I'm working with a CR1000-04000 in Crimson 3.1 and I was interested in adding the...
125
Hi, I have a complex database in Crimson 3.0 and in one of the display pages I am trying to get a tag to show the sum of several other tags. The...
173
It states WinPcap must be installed for the Emulator to function. WinPcap.org states that the technology is mature with no updates planned. Am I...
864
Following on from another thread, I just downloaded Crimson 3.2 and it now supports CR and Graphite HMIs. Time for a 'play' :-) It seems to have...
2,030
