irondesk40
Originally posted this as CTvue, but is actually a red lion display with the control technique drivers.
Pretty new to me so hope someone can give some advice.
This was the original post.
"have downloaded the software to program a Emerson CTvue 306a operator hmi that is used on a machine we are going to redo.
I have a question that I hope someone can asssit with. How do you set the display up to tell it which screen you should be displaying. For example in a allen bradley using panelbuilder software, under application settings/control tags you set up which register in the plc will contain the number for the screen that you would want to display. I have been messing witht the CTvue which is basically a redlion display and can not figure out how you would set up the CTvue screen which register in a allen bradley plc to look at to know which screen to display".
thanks
thanks
