OkiePC
Any time you edit code in a program, you must "translate" it before it will go into the downloaded database. There is a little icon below the menu bar that will turn gray when a program is valid but not translated. It looks like a sheet of paper with a check mark on it. You can click that icon to translate the code or hit CTRL+T. Also, the icon next to your program in the left pane will be yellow when it needs to be translated or red if there are errors. Be sure to end each complete statement of code with a semicolon. You can have one complete statement extend over multiple lines, and Crimson uses the semicolon as the statement delimiter to separate them.
