Redlion G306A Download Error
Pollasit
Jan 2014
Bangkok
Dear Sir,
I have a problem with G306A HMI.
It not boot, but stuck at logo screen with PWR LED flashing.
When I try to download project, this message will be show on crimson3.
"ERROR - unexpected reply code 2.16.2 was received"
This problem occur right after I upgrade my crimson 3 to version 619.002
I guess it might be about firmware or boot sector corrupted.
Is there any way to solve this problem?
Thanks,
Dear Sir,
Thanks,
The easiest way to fix this is to try the download using the RS-232 cable if you have one. Just try the download again that way.
If you don't have one, I would recommend getting one. I bought them for all of our technicians and programmers. It is simply the simplest (although slowest) way to fix most boot problems.
We still use Ethernet and USB for downloading programs, but if that fails, the serial cable will almost always allow us to recover.
Hello, i am new to both the redlion g306A and the Emerson FX-4120. Currently we have a T-21 Data Entry Panel hooked to the Drive. its only...
1,064
Hello. I have a new RedLion G306A HMI and I am having trouble setting the initial IP address. I have worked with many G315C's and expected this to...
3,130
How do I convert the database panelbuilder32 to Crimson 3 I have copied the content of pb32 tag editor to what are the steps to import it into...
1,876
I want to connect an EZMarquee (EZMR-2L20C) to an OMRON PLC: CQM1H-CPU21 and also a G306A Red Lion HMI. This PLC has just one built-in RS-232C...
3,620
Hey guys, hoping someone here could give me a little advice. I'm working with a CR1000-04000 in Crimson 3.1 and I was interested in adding the...
143
