redlion Modular controller and FTP over GPRS
amit22
Jun 2008
gujarat
64
Dear GURUS,
I want to transfer the CF card data as a excel file to FTP server through REDLION CSMSGTRT module with XCGSM expansion cards.
can you please help me out in script? i may be wrong.
i want to transfer 15 tags to FTP server via CF card.
any sample program will helped us a lot.
It appears that your main problem is that the IP address you have defined for your FTP server is a private IP address, so you will never be able to connect to it. The server's IP address need to be a public IP address, so that it can be accessed via the Internet.
A secondary, potential, problem is that you have both the Sync Manager and FTP server enabled. Since you have the firewall turned on, you will not be able to access the unit via ther Internet, so you can disable the FTP server.
Regards,
Dan
I am running a Redlion modular controller with a CSDIO expansion module. I am receiving a pulse at a frequency no greater than 3.6Hz. I have a...
1,950
Does anybody have experience on communication between REDLION modular controller and LOGO! CM AS-Interface...? please revert back if so...
1,922
Hey guys, hoping someone here could give me a little advice. I'm working with a CR1000-04000 in Crimson 3.1 and I was interested in adding the...
149
Hi, I have a complex database in Crimson 3.0 and in one of the display pages I am trying to get a tag to show the sum of several other tags. The...
183
Hi All, Hoping to get some insight into best way to terminate shielded twisted pair + common into a RJ45 required for RedLion RS485...
240
