ian.smith7
Hi All
Ive have converted a program from an old Mitsi F1 to an AB MicroLogigic 1200.
The program uses the High Speed Counter function and switches a series of outputs based on Limit tests of the ACC value. On the rung following each Limit test I have placed a Refresh function to update the I/O.
In order to reduce the processing time I have made the Refresh conditional on the limit test output being on.
My Question is will the Refresh function be active in the same scan that the Limit test is FIRST resovled as true because if not then I might as well take it out.
I suppose I am asking if logic solved as true in rung 3 of the scan is acted on as true in rung 4 of the same scan?
Ian Smith
Ian Smith
