reg-SIEMENS PLC CPU 315-2PN/DP
May 2012
in india
Dear Sir,
I have faced a problem in SIEMENS PLC CPU 315-2PN/DP,the PLC is not communicating with the SCADA.I have called a service engineer,he told me that the program in the CPU got erased.
I want to know that what may be the conditions for program erase in the CPU.
Can you please give me a brief description.
with regards,
c.v.k.kishore
that must be a very good engineer in order to make that conclusion on distance.
I very much doubt the program got erased. but there is no way of drawing a conclusion now because there is not enough information about the system.
Hi, we have a new machine which is capable of communicating with the Control system through the Control net protocol. currently we use a siemens...
4,252
Dears kindly need support to replace old SimoReg DC master Siemens Drive and upgrade to sinamics 6RA8081-6DV62-0AA0 series communication is...
2,470
Dears i need help to enable and run drive manual using terminal block only test it FWD and REV
1,612
Hi, Can anyone provide operating manual for the below mentioned Siemens DC drive : SIMOREG 6RA2675-6DV57 D380/190
1,451
Hi, I'm trying to set up a Siemens Simoreg DC-Master on devicenet without using explicit messaging. I can't figure out exactly how the eds file...
5,883
