Reg-yokogawa DCS
yakub
Nov 2012
hyderabad
28
I Am using RSlogix 5000 software..i have Anlaog inputs...how can i move these analogue values to YOKOgawa DCS...how to communicate with that dcs.I have 1761-NET-AIC in plc panel.which protocol i can use?
Which one of the Yokogawa DCS systems do you have (Centun VP, Centum CS3000 R3, Centum CS, or something else? I think most of the Yokogawa DCS systems use a commmunications protocol called Vnet/IP.
Yokogawa has developed 1-Gbps, open network protocol called Vnet/IP which provides open, reliable, and real-time broadband communications. Both CENTUM and non-CENTUM components can be connected to the network. Vnet/IP protocol is approved as IEC 61784-2 Ed.2.0 and conforms to IEEE 802.3 and UDP/IP.
Vnet/IP has all the advantages of V net, which remains an excellent control network, while offering substantially higher throughput.
  • Compatibility
    Supports V net-compatible protocols and incorporates all V net communications functions
  • Reliability (Redundant bus configuration)
    Features a robust redundant configuration that switches buses quickly in event of failure - equivalent to V net
  • Performance
    Response times are equivalent to V net’s, but throughput is up to ten times greater, depending on the performance of the communications station.
Hi Can someone please tell me where I can find information about the heat developent / dissipation of a Simoreg DC Master? 📚 The information...
940
Hello people This is my very first post in plctalk, so im sorry if my question is out of place. We're using a simoreg dc drive and currently is...
1,525
Dears kindly need support to replace old SimoReg DC master Siemens Drive and upgrade to sinamics 6RA8081-6DV62-0AA0 series communication is...
2,467
Kindly, do you have an idea on how to commission the below two cards, installed on a Simoreg K dc drive ? 6RA8232-1KB0, supplem.board Z1011...
737
Hello All. I have an alarm on a Kinetix 5500 servo amp that I am not sure if it means the drive is done or what. I looked at the alarm code in the...
1,265
