Replace the old Panelview 1200 with the Panelview Plus 1500
mulderm
Jun 2003
Netherlands
298
Hello,
I want to replace the old Panelview 1200 terminal 2711-KC1 with the new Panelview Plus 1500
terminal.
How can I import the old PDS-file ´machine.cfg´ to the new RSView Studio software for
the Panelview Plus 1500?
Greetings,
mulderm
Mulderm:
If I am correct that your PanelView 1200 is an *original* PanelView, then you will need to go through a 2-step process to convert the file for use in RSView Studio:
1. You will first need to convert the PanelView 1200 file into a PanelBuilder 1400e (.pvc)file using PanelBuilder 1400e software.
2. Once you have a .pvc file, you can then import this file into RSView Studio.
If you do not have PanelBuilder 1400e software, I would recommend contacting your local distributor.
Cheers,
Rick
Kindly, can we install new Siemens Sinamics S120 motor modules and new 1FK7 servomotors, in place of old types ? Will the old motion control...
1,127
Good Morning , I'm getting ready to replace some old laptops with Window's 10 laptops. What would be the USB version of the 1747-CP3 ...
1,410
I need to replace an AB PLC. Its an older 2/02 that has only 2 X 16pt 120VAC Input cards (1771-IAD) 1 X 16pt 120VAC output card. (1771-AOD)...
4,327
We have a Beckhoff CP6201 PC and an EK1100 module communicating with it via EtherCAT in one of our machines. Due to problems with the PC, I want...
75
Panelview 2711-K5A8. Customer has 6 of these in service connected to SLC 504’s. One has a bad backlight and I need a solution to replace it...
2,260
